express 300 2x4 with plow any ideas for better traction?
You could source some chains or stud your tires. Thats what I would do... likely both LOL.
Also some bolt on wheel wieghts.
You can always make your own with a small pail that will fit the ID of your rim, fill it with cement and a couple of properly placed bolts to fasten it to the rim. I made my own for my riding tractor, they have lasted me several winters now and weigh more then the ones I was able to readily buy.
My uncle has also filled his tires with an antifreeze soloution for wieght and traction.
edit:
I would be careful loading your suspension too much, the weight is better used actually in or on the wheels. If you load your suspension too much you run a higher risk of drive damage IMO.
edit:
I plowed my house (275' driveway) and my shop (About 1 acre - 1/3 concrete and the rest is stones) all last winter (up to about 7") of snow using my Sport 400 and a Cycle country 48" blade. It has PLENTY of torque to push the snow - and it does NOT have a low gear. I also did not use chains. I simply scooted back on the seat as far back as I could. I angled the blade and made long runs with about 1/8 - 1/4 of the blade free.
Don't let anone tell you that a 2 stroke can't plow. I also had a 1996 Xplorer 300 (Same as yours, but 4wd). I had a very similar 48" Cycle Country plow on that and there wasn't any snow here in Ohio that would stop it. I plowed my old driveway, the street and 3 other neighbor's driveways with that one.
The only time that I have had issues with traction is when we would get a layer of ice before the accumulation of snow. In that case, get a little bit of a running start (Not fast enough to bend anything, though). I'm sure with your chains, things will work out. If you need to, add some weight like the others said.
I studded all my tires with sheet metal screws and I hardly spin a tire now. Mind you I have snow and summer tires, I don't know if I would stud your everyday tires. But as Caper says, too much snow you'll have problems. I'm not saying it can't be done with a 2wd bike but you'll just take longer than a 4wd. Have fun!!!!
