MY Trailblazer just died
#21
#22
135 psi with WOT will be perfect for 93. 150 -160 would be perfect for 107 VP. Check your plug gapping should be .20-.23 on a BR8ES plug. If the coil is going bad gap down from there .16-.18. I agree with flwflh there might be a pinched line and also check the oil lines like he stated. Check the basics first. The oil injection does work well for stock motors, but if it is modified the oil injection does not supply enough. I personally will not run a 2 smoker no less then 32:1. If you checked the basics and ignition, and still doing it then check the reeds for cracks or damage and boot for a vacuum leak.
Yes Im a Chevy man. [img]i/expressions/face-icon-small-wink.gif[/img]
#23
<div class="FTQUOTE"><begin quote>Originally posted by: 468bbc
Yes Im a Chevy man. [img][/img]</end quote></div>
32;1 is a little rich good at times 40:1 is good starting point.
You ever get IN reg. ? Spurgen is open again
#24
Harley, I rechecked the compression and it was closer to 150 both ways...i think the cold the temperature was affecting my judgement. I drained all the gas and put in a couple gallons of 40:1 pump gas/klotz and its smoking a little...very little. I took the line off the oil pump and i have oil flow going in. With the bike running and the line to the intake pulled off at a idle there is no oil coming out. With the bike running at idle. i manually worked the lever on the pump and at the wide open throttle position it would drip a drop every 2-3 seconds. I ran the bike till it was good and hot sitting in the garage and held it part throttle and shut it off to check the plug...
#25
<div class="FTQUOTE"><begin quote>Originally posted by: hurryinhoosier
</end quote></div>
The whole backwards thing to me was why it would have higher comp with the throttle slide blocking incoming air, rather than the slide not blocking incoming air(more available) and giving a lower comp reading. It seemed odd to me was all.
</end quote></div>
#27
#28
#29
#30
