need help with polaris 250 trail blazer
make sure the boot didnt unscrew from the wire. that happens sometimes. have you checked the compression. a new topend should read about 115-120 PSI. anything below 100 will not work very well. usually requires a jug bore to get compression back. could also be as simple as a back spark plug
Shifts
14
07-13-2015 08:41 AM
