need some spec's
i'm getting a polaris 350 cc water cooled 4x4 next month. looked quite a bit and can't find any spec's for it polaris web site only goes back to 2003 i think kind if like to know tire sizes, weight, etc. some one know a web address oe site that can help out a old guy that has never owned a ATV before ? thanks for any info you might come up with.
what is it a trail boss or what is the year and or color? may help to see what you have.
gee's i'm sorry its a 1993. hope pic works it's red and gray think it's a trail something.
http://i287.photobucket.com/albums/l...M/P0000042.jpg |
they only made the 350 in 92 and 93 i think and switched from 348cc to 378cc and called it a 400 most parts will interchange between the 350 and 400
tire size stock is 25x8x12 front 25x11x10 rear |
thanks !
It is a two stroke engine with oil injection. I had a 1992 350 liquid. Same color as the one in the pic. Was a good machine for the miles it had (4500) or so. Check over the chains (all 3) sprockets, bushings counterbalance oil............Get a repair manual for it, chances are you will need it down the road. When you get it you could change the front hub oil, air filter, counterbalance oil, grease, clean, tighten/adjust chains......just my 2 cents.
| All times are GMT -5. The time now is 01:38 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
