Scrambler - 4 Wheel Drive....
What the easiest way to test the 4 wheel drive on the Scrambler, to make sure it is working properly?
I tested the electrical terminals where the coils from the strut plug into. I was surprised that I had continuity, even when the switch was turned off. I was expecting to have no continuity when the switch was in the off position, and that there would be continuity when the switch was turned on. Any input to this, is this correct? |
jack it up all 4 wheels off the ground the rear wheels need to spin 1/5 of a revolution then both front should engage
here is the write up on what to look for with the 4x4
this is what i used to fix my issues ATV Time :: View topic - Polaris Demand Drive Hub Q&A Picture Guide to Service |
