94 400L 4x4 Chain Adjustment
no on the front one.. not the middle or rear but the front.. there is a bolt that needs to be loosened... then you take a long screw driver and tap it with a hammer on the fins of the wheel... you'll see what you need to tap when you look... you should do the rear first then the middle then the front...when you do the rear make sure that when you sit on the quad there is a little slack in it.. it should look loose but tighten up when you sit on it
fordfaithful21
12-07-2015 05:52 PM
Steeldon
09-09-2015 09:38 AM
craacker
09-09-2015 04:32 AM
