4 WD won't activate Help
I rolled my quad and had it repaired. When I rolled it 4WD was engaged and now it won't engage. The front rods spin but the tire doesn't roll with the rod Help please any sugestions...
yr?
Whoever you had do the repairs didn't do a thorough job! Either take it back to them or take it to someone who knows what they're doing!
As in the previous post it does help to include the model and year of your quad as they do have different setups. Or just create a signature in your profile so it's there on all your posts! Welcome to the forum! |
The front shaft spins all the time even in 2wd, its the Hilliary,s engagement that turns the front wheels.Did you screw up your speedo or awd switch in the roll over?
we need top know yr as stated above to dircet you in the right direction as there are 2 differnt systems they used.
Originally Posted by stendori
(Post 2837246)
(Post 2837246)
http://storeyourpicture.com/images/signature_ATV.jpg |
Sorry Guys it is a 2000 Polaris Scrambler 500 4 stroke
Check if power is going to your hubs. Does your awd light on your switch work?
i agree with tlc. the awd light will come on when the 4wd is on. if there is no light then its either a wire, or connection issue. if the light comes on then its the wires to the hubs
| All times are GMT -5. The time now is 08:57 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
