Scrambler special chain? (Quick help)
Decided to replace the chain on my 04 scrambler 500 4x4 today. Called local polaris shop (dont know ANYTHING by the way) and I was told my wheeler may require a special 76 pitch chain? If so, a normal scrambler chain would not fit onto my sprocket. Every other place I search says ALL chains are interchangable from 98-2009. Whats the deal? Anyone hear of this before? Also reading that better off with a non oring chain vs an oring one. I mostly ride trails, mud, and winter riding. Any input before I order the wrong chain.
As far as the oring chain versus a standard chain. My Oring chain lasted 6 years, 500 miles...I was in a pinch and no dealer within 100 miles so I stopped at farm supply store, they matched the chain up, same link size...they cut to length and handed me a master link. Only it's a standard chain, non oring. Yes, it is a little louder, I hear it once in a while in reverse but don't really notice it forward. This chain has been on my machine for 5 years now, 700 miles, so it's lasted more miles than the oem chain. I keep it well greased and it's held up great. I notice no premature or uneven wear on the sprockets, and to be honest it hasn't needed to be tightened or stretched any more than the oem chain. It's been fine. If I need a new one I'll go right to the farm supply store and buy another for $10. I surely would have purchased a oem chain if it was available at the time but I have no issues with the standard chain bought at the farm supply store. My experience anyway.
No problem with money. Just want a good chain that fits. Bikebandit lists different part numbers for an 03 and 04 chain. Just made me wonder. I was going to order a o-ring chain of ebay for 98-09 scrambler 500 which I assumed was already at the correct length. Just concerned that they said all years fit but bikebandit claims the 03 and 04 chains are different. Local dealer cant tell me anything thats not written in there book. Took them 3 attempts to get me the right axle nut. So Im assuming based on OPT post that there is no real difference between scrambler 500 chains. Will check again after work so if someone knows otherwise please let me know
