OK Old Pros, I need some serious diagnosis!
#41
Todd,
The noise in the fan is due to bad bearings. The fan is easily disassembled. One of the bearings will easily pull off. The other has to be cut. I used a dremmel, but any kind of grinder will do. The bearings can be replaced at any bearing house for $3 each. It is a 1 hour jobs including removing the front bumper, rad, and fan motor. I beleive the bearing is a 608, but they can match yours up after you remove it. The only other thing is that motor that acually makes physical contact is the brushes, and I have never seen brushes actually wear out on one of those motors.
Be sure to line the o-rings back up good upon reassembly. I used some silicone to make sure I got a good seal. The problem with these motors is the o-ring around the fan motor shaft. They leak water, and there is nothing I have found that can be done about it. Also, the is not need for excess lubricant when you reassembly the motor. I usually just put a bit of lithium grease on the surface that the brushes contact.
Good luck,
Greg
Good luck,
Greg
#42
Customer Service #1
05-15-2020 08:46 AM
