Scrambler 400 no start +backfire. Ran fine,sat in cold 1 week,almost started....
I have a 99 scrambler 400 that has never given me an issue as far as starting and running.
I ran it around the block a few times and parked it outside, uncovered for about 2 weeks. It is now 20 degress. I started it up to plow, and with the choke it ran for about 5 seconds...i goosed it as it tried to die and it did. This happened about 5 or 6 more times til it wouldnt even start...not even try...choke or none....but it would backfire like a mf'er.
So i took it in my garage and am letting it warm up. It SHOULD be warm now, but no go
What should I do next?
I guess logic would tell me to remove the spark plug...
anything else?
anything else?
I just dug a little deeper...the plug is wet, but not fouled...i left it out so everything dries up some...might take a while since i was cranking for 60 secs+
Also, i found the coolant res. to be bone dry. it always leaked a little visibly, but never enough to affect the level. this is very wierd to me. i had some polaris antifeeze somehere, but cant find it. does a normal 50/50 blend work okay? this really concerns me
Okay....
So I took the plug out and it was very wet....dryed it off....let everything air out for about 6 hours. Put the plug back in...and same scenario....got it 'started' for about 3 seconds...then died. The started for about 3 seconds...then died....then crank crank crank crank
ideas? it ran great til i let it sit for a bit
well, same thing happened....started up for about 5 seconds, cut out....started for 3 seconds, cut out...then BAAAAAAAM big backfire....then started for 3 seconds etc etc
eventually i was able to goose it enough to stay running and i've let it idle now for a good 20 mins. white smoke out the muffler seems a little excessive, but it could be my imagination
IF there is a head gasket leak, it would make sense that it could be leaking into the spark plug chamber, and making it tough to keep ignition going? perhaps that's why it ran okay, but then after sitting overnight had the same problem? or, maybe all the old gas wasnt out...after all.....the gas appeared to be the big issue here because once it was drained and refilled with heet-treated gas, it ran okay.
i'll compression test later and post results
i should do it cold at full throttle, right?
well, i tested compression (what a mf'in PITA to get that thing threaded in there with the tube getting in the way)
110psi after 3 or 4 seconds cranking 2 times, 2nd time with a little throttle
So.....what's that tell me? it's good i guess, but is there a possibility still of a head gasket leak?
