Engine won't idle and sometimes idles to high
Old Dec 27, 2009 | 06:39 PM
mpolaris111's Avatar
Default Engine won't idle and sometimes idles to high
I have a 2007 polaris sportsman 500 EFI deluxe that won't idle and sometimes idles to high and will not idle down. The check engine light is not coming on and it does not seem to go onto high idle when the engine is cold. Anyone have any ideas?
Old Dec 27, 2009 | 07:04 PM
4getful2's Avatar
does the throttle feel like it has too much slop in it?? maybe the cable has ice in it ,not letting it return to idle
Old Dec 27, 2009 | 08:55 PM
NewportHillClimber's Avatar
possibly leaking crank seal. allowing it to suck air and thus run lean. if its not there then it sounds like you have an air leak somewhere
Old Dec 28, 2009 | 04:36 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
make sure throttle cable isn't getting bound up or is too tight. should have about 1/8" play as you squeeze the throttle.
Old Dec 28, 2009 | 04:39 AM
MN250R's Avatar
sounds like an air leak
Old Dec 28, 2009 | 07:55 AM
skunksquasher's Avatar
hey mpolaris111,
Please check where your intake bolts onto the engine. I have the same machine as you, and had the same symptoms. Turns out that one of the intake bolts had worked its way out completely, and the other one was on its way. The whole intake and throtle body assembly was just flopping around down there. miracle it ran at all. The intake gasket had a tear in it, so I replaced that and the missing bolt and tightened everything up and all is back to normal.
Old Dec 30, 2009 | 02:22 PM
How would I know where the air leak was if it was that?
Old Dec 30, 2009 | 02:23 PM
Everything checked out ok
Old Dec 30, 2009 | 02:24 PM
Everything was tight. Any other ideas?
Old Dec 30, 2009 | 04:22 PM
crank seals. and i had a polaris i serviced once that when the tank ran low on gas it would run wide open. you may wanna try adding fuel to tank
