No 4X4 - sPEEDOMETER Quit Working
The speedo became involved in the operation of the AWD in 2000 so your in there. I have never done it but there is a easy by pass of the speedo to get your awd back. I would use the search option of this site to find a detailed post about it.
I,m with you ,if my speedo quit working I would not buy one for $300 and would just by pass it also.
Brown wire w/white stripe needs to be connected to the all brown wire. This was based off of a wiring diagram & old posts for a '99-04, but it also worked on my '05 sportsman 400 that had a hell of a lot more wires on the speedo plug than the older models.
Just make sure you only hit that switch when you are already WOT stuck in the mud.........................
Kidding! Don't do that! Be careful because now that switch can cause some damage. Only hit it when fully stopped, as in wheels NOT moving.
