ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   I'm stuck (literally), PLS NEED HELP (https://atvconnection.com/forums/polaris/323179-im-stuck-literally-pls-need-help.html)
Jrthom Jan 31, 2010 11:03 AM
Ok, i have 2006 sportsman 450 for about 2yrs now. I rolled it over end for end about a year ago. since then the speedo assembly no longer exists. as of last night the atv is stuck in a field in 2feet of snow lol. The awd does not work anymore obviously since unhooking speedo assembly. Can anyone tell me which/how to make awd work without it? All wires, plugs are still there but i need to know how to bypass everything if possible.
Thanks
stendori Jan 31, 2010 12:59 PM
try grounding the brown/white wire(number 16 in the plug) on the speedo harness that plugs in. this might give you awd. welcome to the forum.
Jrthom Feb 2, 2010 01:29 PM
Update for Sten
Ok, here's what i found out. I had no power going to awd plug in transfer case. with a tester i found that the brown/white (16) was a live wire in the harness, so grounding it didnt seem right. after further testing the white wire (14) had to be spliced with brown/white (16) to put power to awd. I tested it out and the awd was working but then I smelled the "whats burning" smell lol, i checked everything and the plug into the transfer smells like its burning. I let it cool down for about 10min and started it up and awd worked fine again until i smelled that smell again ( electrical wire burning). Any ideas whats causing it to get hot and quit working? btw thanks for the info before, I had no clue where to even start.
Thanks
© 2026 MH Sub I, LLC dba Internet Brands
