Need 2004 1/2 Sportsman 700 Wiring Diagram
Hi- I am in need of a wiring diagram for a 2004 1/2 Sportsman 700, We are having an overheating issue. I am trying to locate a relay or switch that will fix this issue that is supposedly hard to locate.....but not sure I can tell you which one it is at the moment. Where can I find the diagram?
BTW...Awesome site! I'm glad I came across it.
Thanks in advance!!
Thanks in advance!!
If its not the fan its the switch in the radiator, located in the lower right hand corner of radiator, you can buy one from your local parts house ,the number is Wells # SW 526, the ends may not be the same but you can cut the one off the old switch and splice it to the new one, just leave plenty of wire to do it, Too long is better than too short
ranvette
07-04-2015 06:13 PM
