ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   1994 400L won't start (https://atvconnection.com/forums/polaris/330662-1994-400l-wont-start.html)
xsperf Sep 6, 2010 03:18 PM
I just bought a 1994 400L which supposedly just had the transmission rebuilt(by a shop and I have a receipt) as well as the engine rebuilt and over bored to 500CC. The engine wasn't done by a reputable shop though, just his 'buddy'.
Anyway, it ran great for a few hours, then it started running really badly and smoked quite a bit(blue), I figured the fuel tank vent hose was clogged and I let it sit overnight and decided to try to start it in the morning. Well, every time I come to start it, it backfires. It seems that the timing is off and it is igniting the spark in the compression stroke pulling the pull-chord right out of your hand and backfiring..
Is there a flywheel key on this thing, or how do I check the timing and fix this?
Also, I started it up without the battery one time(because I forgot I had taken it out) and all the lights randomly flashed, the Neutral, Reverse, Hot.. etc lights. When I put the battery battery back in, none of the lights work. Did I burn a fuse or something?
Thanks, and sorry for the long post.
Overdrive Sep 6, 2010 04:19 PM
You fried every light that was on when you started it without a battery. It will happen every time you do that. All you need are bulbs.
xsperf Sep 6, 2010 05:31 PM
Good to know, thanks.
Any chance that the spark plug could be causing the pre-ignition? I just don't see how the stator plate could have moved overnight without it being touched, is there any other explanation to this?
© 2026 MH Sub I, LLC dba Internet Brands
