08 Sportsman 800 Parking???
Old Sep 15, 2010 | 08:43 AM
badazzpred's Avatar
Default 08 Sportsman 800 Parking???
I notice whenever I'm riding the wheeler and I come to a complete stop to shift into park it seems to go into gear but then I have to rock the wheeler just a little and it falls all the way into park is this normal? and has anyone else discovered the same thing?
Old Sep 15, 2010 | 09:32 AM
TLC's Avatar
TLC
Not familiar with the 800 ,put if it was a 500 id say it just needs a touch of a turn on the linkage rod adjuster between the shifter and tranny.
Old Sep 15, 2010 | 01:05 PM
switzomatic's Avatar
Check for any slop in the shifting mechanism. Sometimes the aluminum piece that the rod goes into (attaches to shaft on the tranny) gets worn. Also, I had hard shifting problems(mostly in the cold) that I found was due to a crappy sealing job from the factory. They only use a small bit of silicone on the shifter housing located on the tranny. I pulled it off, made a gasket, sealed both sides with anaerobic schmoo, and lubed the cogs inside before putting it back together. Goes through the gears now like a hot knife in butter! Also, are you stepping on the rear brake going in/out of park and high? Supposed to make a difference.
Old Sep 15, 2010 | 04:03 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did have enough miles on mine to have any shifting wear parts. mine always dropped right in.
Old Sep 15, 2010 | 11:19 PM
badazzpred's Avatar
I always pull the front brake or step on the rear brake before shifting into park.......
Old Sep 16, 2010 | 08:19 AM
If using the brake then I would check the stuff mentioned. Made all the difference in the world on my 09.
Ronk407NY
Feb 13, 2016 11:05 AM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Stirling
Aug 9, 2015 01:49 PM
toonces
Aug 5, 2015 05:55 PM
