04 Polaris Predator 50 will not start
This 5 buck manual will give you the specs on the stator and other electrical checks,along with the wiring schematic. Minimum compression is 115 psi per the manual.Shorted out resistor in the plug cap can cause the problem,but check the bare wire against the cylinder for spark.2004 Polaris Predator 50 Service Manual PDF Download
Checked compression? Manual calls for 115psi minimum. Any lower than that and you can have problems.
whitty
67
02-24-2021 02:52 PM
Predator_500
06-13-2015 03:01 PM
