2008, 800 Sportsman Touring Question
Ok, I am new at this and in the process of learning.
I have only found 4 grease fittings on my first used 4x4. This, as the title states is on a 2008, Sportsman 800 Touring model. These are on the upper "A" frame (bushing) joints. I believe there is one on the main drive shaft also. Haven't looked for it yet.
IS THIS ALL THERE IS? And, if this is true, any thoughts on why?
It would seem the lower bushings are just like the upper bushings except there is no way to lubricate them.
I think you can get after market universal joints that have grease fittings. It just seem like an additional expense that Polaris should have provided in the first place.
Let me know your thoughts
tumblebug
tumblebug
Not many grease fittings on the 800 or really any later model compared to the early days. The first generation of Sportsman 500s with the rear u-joint drive shafts had over 20 somethings fittings total!
The newer bushings,ball joints,etc were called "life time greased" which we just laughed at at the old shop! Just a cost cutting measure I guess? OPT
Note sure about the 800's but I just greased my 08 500 Touring this morning and there are 4 zerks on the rear and 4 on the front arms. Two on each end of the swing arm. I think you need to go and look for the ones you did not find. I also have looked at the drive shaft and cannot find a zerk anywhere so the joints are on their own until they fail.
bzdok1234
30
02-23-2016 01:55 PM
