ATVConnection.com ATV Enthusiast Community (https://atvconnection.com/forums/)
-   Polaris (https://atvconnection.com/forums/polaris/)
-   -   97 Xplorer 400 don't wanna stop! (https://atvconnection.com/forums/polaris/346516-97-xplorer-400-dont-wanna-stop.html)
Tim1962 Sep 29, 2012 02:19 PM
Hey all, new to here and hoping someone can give me a bit of advice!
I have a 97 Xplorer 400 that sometimes will shut off with the kill switch or ignition and sometimes it won't. I have shut the ignition off, turned off the kill switch and she just keeps on running. The only way I can stop it is to choke it...any thoughts on where to start looking?
Thanks
old polaris tech Sep 29, 2012 05:34 PM
Welcome! Pop the front panel and check the black wire from the cdi has a good connection. This is the kill circuit wire. If it appears to have a good connection,could be the kill circuit has shorted out within the cdi module itself. I've had a few of these do this,some customers would replace the cdi,some just decided to turn off the switch and choke em down like you. Hopefully it's just a connection problem on the black wire. OPT
Tim1962 Sep 29, 2012 07:00 PM
Thanks for the reply, I was cleaning the bike up today, doing some adjustments but a bit timid of messing with the electrical. I will check it out tomorrow and see if cleaning up the board helps any!
© 2026 MH Sub I, LLC dba Internet Brands
