2005 Polaris 500 Ho speedo problem
I have a 2005 polaris 500 ho and my speedo and mileage stoped working. Everything else works on gauge. Any advice?? Thanks
First check that the hall effect sensor is plugged into the speedometer.If the speedometer doesn't work and mileage doesn't accumulate, the hall effect sensor located on the caliper has usually shorted out. You can clean this area up to see if dirt/mud may be blocking the sensor. If doesn't help then replace it.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Item #21
OPT |
Part #21 (hall Effect) $44 http://www.cyclepartswarehouse.com/f...005&fveh=39672
http://images.powersportsnetwork.com...72_9416c01.gif |
