Want to add a recoil to a 2012 400HO.
Would anybody have a part number for a recoil for my 2012 400HO?
Any recoil from an older 400 or 500 Sportsman,Scrambler will work if you want to check Ebay. #3090085 is the recoil assy at Cycle Parts Warehouse. Runs a little over $200 for a new one complete except for the bolts. OPT
Except for the bore and stroke all the Fuji motors are the same,425,455,500 of any year,so a used recoil should be easy to find. May need the part for the flywheel that the pull starter catches on to, to turn the motor over.
I should be able to get a new one from my dealer, correct?
If you want a new one(#3090085) get it from Cycle Parts Warehouse or Cheap Cycle parts,the dealer will be always more,BUT check shipping costs and compare. This is just a simple bolt on using your original bolts as all the flywheels still have the vanes to catch the ratchet on the recoil! This was just a way to cut costs,corners or both when Polaris omitted the full recoil and just installed a blank cover! OPT
Originally Posted by WilliamBos
(Post 3158025)
Originally Posted by TLC
(Post 3158039)
They will $ell you anything. But why get one for $250 when there are plenty for $50 on ebay.
I emailed them, will post back when I hear. http://www.ebay.ca/itm/Recoil-Asm-Po...1#ht_500wt_922 |
Thats a rip off Canadian ebay site. I, know I,m from Canada.
go to "ebay .com" not "ebay .ca". these guys sell them for $183 , new.3087054 ASM-RECOIL* $183.26 should be $38 to ship to Canada. here is one for $120 used. http://www.ebay.com/itm/2002-POLARIS...sories&vxp=mtr |
