What size is front hub seal on 350L 6x6?
Dear friends,
I'm really lost without your help. I try to get a front hub seal for my Big Boss 6x6 350L from 1993. The problem is that what I mesured is not the same what sellers offer for this ATV. Another problem is that the ATV is running in Africa and I'm not able to take out the old seal to take it to a Polaris Dealer. Even on the seal there is no longer any number or size. In concordance to the Online Parts Catalogue the seal should be Polaris Parts No.3610019. But even my Polaris Dealer in Germany was not able to tell me, if the seal would fit well on my ATV. I'm not used to inches, but I tried to mesure the old seal:~82mmx~66,7mmx~8/10mm what could mean: 3,23"x2,63"x0,31"/0,39" Does anyone knows the exact size and part number of this seal? From where could I get it? It would be a big help for me. Regards buschmaschine |
Its part number is 3610028 from this site.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse cost is $8.79
Same seal my 2001 Sportsman 500 used and most all hillary hub drive Polaris ATVs have used throughout the years. Pretty well, Polaris only made one front strut/hub assembly and put it in all there 4wd ATVs until they switched to the centralized single Hilliary in the front diff in 2004. |
I recently asked this guys to help me with the exact size of this seal. Maybe I get the details I need and can order from there.
Does anyone else knows the exact size of the seal under this part number? Regards buschmaschine |
3610019 hub seal and 3610028 hub strut seal are the only seals used as mentioned in Polaris atvs. Here's a replacement and dimensions for the 3610019 hub seal if this is what you want.If you need the strut seal dimensions also just enter 3610028. Polaris 3610019, ATV Parts Cross-Referencing
OPT |
Great!
That's what I was looking for. I thought this seal would be an INCH size seal. This ATV is really mixed up with Metric and INCH Parts! Thanks again to you guys. Regards buschmaschine |
You have to have both metric and standard tools to work on a Polaris! Engines are metric, the frame bolts and nuts are standard along with the suspension nuts and bolts and the gear cases. :huh: The only ones that have it one way are the imported Asian models. The little 50s, 90s, Hawkeye ,Phoenix,and Sawtooth. All metric! OPT
