Polaris Xpedition tool search
Old Jan 20, 2013 | 01:51 PM
sruigrok's Avatar
Default Polaris Xpedition tool search
Well so far these quads are a pain in the butt to work on! i would like to know if anyone knows where i can buy the tools to remove the clutches. i have searched all over the net with no luck. The secondary clutch looks like it needs a holding tool with 4 pins or something with a handle attached. The primary? i have no clue. the manual just says use the clutch removal tool. i have not a clue what it even looks like!
Any help here would be greatly suggested. all im trying to do is replace the shift shaft, and ya i tried. you have you remove the clutches to change out the shaft.
Old Jan 20, 2013 | 07:48 PM
Try this place.Should have all that you need in the way of specialized tools.If you don't see what you need you can contact them. https://polaris.spx.com/DisplayByCategory.aspx?cat=1
OPT
Old Jan 21, 2013 | 05:23 PM
Inrbigness's Avatar
Just go online and get some polaris clutch pullers. You can hold it in place with a prybar and the puller just threads into the outside of the clutch and pushen on the crank and pulls the clutch outwards. They are about 35 each online.
Old Jan 22, 2013 | 07:22 AM
If it's an Expedition 325 or 425 it has a wet clutch like a motorcycle and has a 5 speed transmission. It does take some funky specialized tools to work on these engines. OPT
Old Jan 22, 2013 | 10:28 AM
Inrbigness's Avatar
Ah okay. I had an old Xpedition 400 so that was what I was thinking.
Cole Hadden
Jun 15, 2025 09:05 AM
Captjay
Jul 23, 2015 12:33 PM
toonces
Jul 21, 2015 02:40 AM
Shifts
14
Jul 13, 2015 08:41 AM
Mikea1978
Jul 4, 2015 12:37 PM
