1996 sportsman 400 rev limiter override???
Item #40 under the front panel. Just pull the black wire. You'll have full power and awd in reverse without having to push the override button.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
OPT
OPT
OPT
It's an electro/mechanical awd system. You have to have a good battery to start with, If you don't have awd in reverse it could be that you have a problem in the wiring going to the hubs(small wiring connectors under the front panel)or a mechanical problem in the hubs. Plus if you haven't changed hub fluid in awhile it might be time to try this also. OPT
cody500ho
14
08-14-2015 05:03 PM
house1
08-09-2015 10:49 PM
