Mixing polaris 2 cycle oil
Does anyone know if I can mix Polaris 2 cycle oil straight into the gas or does it have to go through their oil injection system. If I can straight mix it, how much would I need per gallon for a 32:1 and 40:1 ratio.
1 Attachment(s)
You can premix Polaris oil along with most other good quality 2 stroke oil. Usually says on the bottle premix or injector applications. Premix at 40-1.
Thanks OPT !! Can I premix injector oil ?? I guess I should have been more clear. I have plenty of injector oil laying around, but I want to do away with oil injection on the predator 50 (the oil pump is shot). So I was hoping I could still use it up instead of having to buy more oil.
Just look at the bottle label you can use it either way,same as for most other 2 stroke oils.
