Polaris sportsman 500 Failed camshaft
#15
#16
They show to have a warranty if installed by a dealer?? Many knock off parts are starting to show up now,some may be ok,some others questionable.But like they say,the warranty is only as good as the one that does the warranty? This place on Ebay could be here one day,gone the next? With the Cycle Parts Warehouse parts I ordered,they came in Polaris oem wrapping..
#17
#18
No gaskets needed. The head doesn't come off. The cam chain tensioner gasket usually stays on the cylinder,the cam removal cover has an o-ring that you can reuse,the thermostat housing(that has to be removed) reuses the gasket around the thermostat. Easy to change the cam and rocker arm out,IF you do it the right way.Plus the oil tank screen needs to be cleaned and engine sump drained before you install new oil and filter.
#19
Thanks for all your HELP.
My dad ( I am 37) pretty much supplies us with machine's to drive.
I myself have a 1999 Polaris Xplorer.
He owns a bunch of ATV's - what man needs more than just a couple of ATVS ?
The least I can do is try to fix the machine he allowed me to drive for years !
Kyle
#20
