Alternator bad? 2008 Sortsman X2 800 LE
I have a clean low hour 2008 X2 800LE that I bought new.
I always have to keep the battery charger on it, as the machine will not charge the battery at all. At idle it has 12.20 volts and it goes down if I rev it and down even more if I turn on the headlights.
Is the alternator on this thing an easy repair?
Most of the time it's a faulty regulator/rectifier located at the front of the machine. You can check the stator yellow wires on the connector to make sure none have shorted to ground to eliminate the stator as the problem.I'd have the battery load tested also as it's a strain on a battery when this happens.Item #1 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Scooter's Shop
23
Oct 22, 2015 07:04 PM
