Polaris Sportsman Brake service.
Take the 3/16" plug out,you can use a big screwdriver in between the pads to push the piston back and pry the end of the outer pad off the slide end where the plug was removed.That's one of the reasons for the plug to allow the slide to move back a little further on that end.Then just pry off the other end and remove the inner pad the same way.Then you can just pull the slide out and grease it. One rubber sleeve will stay on the caliper,one will come of with the slide. Once you get the pads replaced and calipers mounted,pump up the brakes until the master cylinder builds up. Install the plug on one side,spin the rotor slowly as you tighten the plug. When you feel a slight resistance,back off the plug 1/8 turn.This sets the inner pad against the rotor and helps align the caliper. Do the same for the other side and you're done.
Thanks OPT. Do I need to lock tite the plug in??
toonces
10-16-2019 12:11 PM
bzdok1234
30
02-23-2016 01:55 PM
