05 sportsman 700
05 sportsman 700
Cranks up runs fine but when shut it off and try to start back up will sluggishly turn over three times then nothing let it sit ten minutes and will start back up??? Has new starter, solenoid, cdi box and coil up grade, battery all grounds grind down to bare metal and replace all connection dialectic greased
Check the tank vent for any kinks,possibly a carb kit if you haven't checked it out. Sounds like you've addressed most of the electrical as a problem area,but check that you're charging 14 volts back to the battery at an idle from the regulator/rectifier also.Plus not a bad idea to do a compression check to see where you stand on the top end.
chingchangchong
08-07-2022 11:36 AM
slowgsxr97
09-08-2015 07:33 PM
cdstang
08-31-2015 07:52 AM
