07 Sportsman 500 no high beam, no power outlet
So i just noticed my high beam and my aux power plug isnt working. Not sure how long they have been out as I very seldom use the high beam. Is there a fuse for this? I havent found any fuses at all on this machine. There were a couple spares in the front box when I bought it but have yet to find where they go. Any help?
Pull the headlight pod cover and check the yellow wiring going to the headlight connector. Seems like this was a bad spot for shorts and also ground(brown) wire problems because of all the twisting and turning and the wires bunched together.Plus the headlight wiring had to make some sharp bends. A bad ground wire could be the cause of the aux power outlet also.
bzdok1234
30
02-23-2016 01:55 PM
KimSJoh
14
07-18-2015 07:20 PM
