Recommendations for Scrambler 500 clutches
I've removed both Primary and Secondary clutches from my 01 500 Scrambler today. They were extremely wore and made horrible racket. I've looked around on eBay and don't want to buy used because I would hate to replace my old one with another that was just as loud.
Any recommendations on best place to buy primary/secondary as a set online? |
As long as the front clutch spider and guide button lips aren't worn down and grooved,cheaper to rebuild one. Same for the rear. Only special tool needed is the spider tool available on ebay. Usually just clutch buttons in the rear clutch as long as as the helix isn't trash,plus if needed it's only about 40 bucks. Parts are available here along with several other online sites.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse |
Mine was wore really bad, cracked, slack everywhere.
I'm just going to replace both. I'm trying to find out what all is interchangeable from different models. Looks like the sportman's may swap out with the scramblers but not sure what all models. |
All non ebs drive and driven clutches are basically interchangeable. Just use your weights and springs if you can find decent used ones,but you still will probably have to install new guide and ramp buttons. Here's your drive clutch number and what all share it..
Usage : 1321632 Year Product Model Assembly SERIES 10 RGR RANGER DRIVE CLUTCH - A10RB42AA SERIES 10 RGR RANGER DRIVE CLUTCH - A10RD50AA SERIES 10 RGR RANGER 500 6X6 DRIVE CLUTCH - A10RF50AB 2002 ATV SCRAMBLER 400 2X4 DRIVE CLUTCH - A02BA38CA 2002 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A02BA50AA/AB 2002 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A02BA50AA/AB 2002 ATV SCRAMBLER 400 4X4 DRIVE CLUTCH - A02BG38CA 2002 ATV SCRAMBLER 500 4X4 DRIVE CLUTCH - A02BG50AA/AC 2002 ATV SCRAMBLER 500 4X4 FREEDOM DRIVE CLUTCH - A02BG50AA/AC 2002 ATV TRAIL BOSS DRIVE CLUTCH - A02CA32AA/AB 2002 ATV XPLORER 400 DRIVE CLUTCH - A02CG38CA 2002 ATV SPORTSMAN 400 DRIVE CLUTCH - A02CH42AA 2002 ATV SPORTSMAN 400 DRIVE CLUTCH - A02CH42AA 2002 ATV SPORTSMAN 400 DRIVE CLUTCH - A02CH42AA 2002 ATV SPORTSMAN 500 ALL OPTIONS DRIVE CLUTCH - A02CH50 ALL OPTIONS 2002 ATV SPORTSMAN 6X6 DRIVE CLUTCH - A02CL50AA/DA 2002 ATV INT'L BIG BOSS 6X6 DRIVE CLUTCH - A02CL50AA/DA 2001 ATV MAGNUM 325 4X4 DRIVE CLUTCH - A00CD32AA 2001 ATV MAGNUM 325 4X4 MOSE DRIVE CLUTCH - A00CD32AA 2001 ATV 325 MAGNUM 4X4 HDS DRIVE CLUTCH - A00CD32AA 2001 ATV TRAIL BOSS DRIVE CLUTCH - A01AA32AA 2001 ATV TRAIL BOSS DRIVE CLUTCH - A01AA32AA 2001 ATV TRAIL BOSS 325 SE DRIVE CLUTCH - A01AA32AA 2001 ATV SCRAMBLER 400 2X4 DRIVE CLUTCH - A01BA38CA 2001 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A01BA50AA 2001 ATV SCRAMBLER 500 2X4 DRIVE CLUTCH - A01BA50AA 2001 ATV SCRAMBLER 500 4X4 DRIVE CLUTCH - A01BG50AA 2001 ATV SCRAMBLER 500 4X4 DRIVE CLUTCH - A01BG50AA 2001 ATV MAGNUM 325 2X4 DRIVE CLUTCH - A01CB32AA 2001 ATV MAGNUM 325 2X4 DRIVE CLUTCH - A01CB32AA 2001 ATV 325 MAGNUM 2X4 HDS DRIVE CLUTCH - A01CB32AA 2001 ATV XPLORER 400 DRIVE CLUTCH - A01CG38CA 2001 ATV SPORTSMAN 400 DRIVE CLUTCH - A01CH42AA 2001 ATV SPORTSMAN 400 DRIVE CLUTCH - A01CH42AA 2001 ATV SPORTSMAN 400 DRIVE CLUTCH - A01CH42AA 2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 500 DUSE HO DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 500 RSE HO DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 500 HO DRIVE CLUTCH - A01CH50AA 2001 ATV WORKER 500 DRIVE CLUTCH - A01CH50AA 2001 ATV SPORTSMAN 6X6 DRIVE CLUTCH - A01CL50AA 2001 ATV INT'L BIG BOSS 6X6 DRIVE CLUTCH - A01CL50AA 2000 ATV TRAIL BOSS DRIVE CLUTCH - A00AA32AA 2000 ATV TRAIL BOSS DRIVE CLUTCH - A00AA32AA 2000 ATV TRAIL BOSS DRIVE CLUTCH - A00AA32AB 2000 ATV SCRAMBLER 2X4 DRIVE CLUTCH - A00BA38CA 2000 ATV SCRAMBLER 400 DRIVE CLUTCH - A00BG38CA 2000 ATV SCRAMBLER 500 DRIVE CLUTCH - A00BG50AA Here's the list on the driven clutch. Usage : 1321798 Year Product Model Assembly 2009 ATV SCRAMBLER 2X4 INTL DRIVE TRAIN, SECONDARY CLUTCH - A09BA50FA 2009 ATV SCRAMBLER 500 4X4 DRIVE TRAIN, SECONDARY CLUTCH - A09BG50AA 2009 ATV SCRAMBLER 500 4X4 INTL DRIVE TRAIN, SECONDARY CLUTCH - A09BG50FA 2008 ATV SCRAMBLER 2X4 INTL DRIVE TRAIN, SECONDARY CLUTCH - A08BA50FA 2008 ATV SCRAMBLER 500 4X4 DRIVE TRAIN, SECONDARY CLUTCH - A08BG50AA 2008 ATV SCRAMBLER 500 4X4 INTL DRIVE TRAIN, SECONDARY CLUTCH - A08BG50FA 2007 ATV SCRAMBLER 500 2X4 INTL CLUTCH, DRIVEN - A07BA50FA 2007 ATV SCRAMBLER 500 4X4 CLUTCH, DRIVEN - A07BG50AA/FA 2006 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A06BG50AA/FA 2005 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A05BG50AA/FA 2004 ATV A04BG50AA SCRAMBLER 500 4X4 DRIVEN CLUTCH - A04BG50AA/FA 2003 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A03BG50AA 2002 ATV SCRAMBLER 500 2X4 DRIVEN CLUTCH - A02BA50AA/AB 2002 ATV SCRAMBLER 500 2X4 DRIVEN CLUTCH - A02BA50AA/AB 2002 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A02BG50AA/AC 2002 ATV SCRAMBLER 500 4X4 FREEDOM DRIVEN CLUTCH - A02BG50AA/AC 2001 ATV SCRAMBLER 500 2X4 DRIVEN CLUTCH - A01BA50AA 2001 ATV SCRAMBLER 500 2X4 DRIVEN CLUTCH - A01BA50AA 2001 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A01BG50AA 2001 ATV SCRAMBLER 500 4X4 DRIVEN CLUTCH - A01BG50AA 2000 ATV SCRAMBLER 500 DRIVEN CLUTCH - A00BG50AA 1999 ATV SCRAMBLER 500 DRIVEN CLUTCH - A99BG50AA 1998 ATV SCRAMBER 500 DRIVEN CLUTCH - W98BC50A These are ones that share the same part numbers,BUT others can be used.. |
Thanks for all the information, I greatly appreciate it. This is my first Polaris, typically I stick with Honda's to buy/resell. Polaris is sure proud of their parts, or maybe it is just their scramblers?
You can try several online sites such as Cycle Parts Warehouse,Cheap Cycle Parts,Partzilla,etc,but complete new clutches aren't cheap no matter where you get em..
