02 Sportsman 500 HO CV Axles
Well, it seems like OPT has helped me so much that I got my machine working very well. I went to Croom ATV park and tore it up yesterday and had a BLAST! You know the saying, "If you don't break anything, you aren't having enough fun". Well I had A LOT of fun. That being said, I am in need of at least one CV axle (front right). My question is, is the front right and left the same part numbers? (Can I just order 2) or are they different? Also, Where do I find the proper part numbers so if I purchase them from somewhere that has the year and model listed I can compare part numbers. I am also looking for a new FAN part number as well. (fan bearing sounds shot). Thanks in advance.
Drive shafts are the same. Plus you can either get oem or there are plenty of after market ones from ones on ebay or even Epi or Gorilla drive shafts. Plus you can get just the cv joint or even the u joint if that all's what's damaged along with oem boot kits. Stay with oem boots if you go that route!
Usage : 2200960 Year Product Model Assembly SERIES 10 PPS PTV 6X6 DRIVE SHAFT - C10CL50AA (4978707870B01) 2003 ATV SCRAMBLER 500 4X4 DRIVE SHAFT - A03BG50AA (4975687568A14) 2003 ATV SPORTSMAN 400 DRIVE SHAFT - A03CH42AA/AB/AC (4975687568A14) 2003 ATV SPORTSMAN 6X6 DRIVE SHAFT - A03CL50AA (4975687568A14) 2003 ATV SPORTSMAN 500 HO FRONT DRIVE SHAFT - A03CH50AA/AB/AC/AD/AE/AH/AJ (4975687568A14) 2002 ATV XPLORER 400 CV JOINT - NEAPCO - A02CG38CA (4970247024B03) 2002 ATV XPLORER 4X4 CV JOINT/NEAPCO - A02CG25CA (4969856985B01) 2002 ATV SCRAMBLER 400 4X4 DRIVE SHAFT - A02BG38CA (4974677467C02) 2002 ATV SCRAMBLER 500 4X4 DRIVE SHAFT - A02BG50AA/AC (4970027002B02) 2002 ATV SCRAMBLER 500 4X4 FREEDOM DRIVE SHAFT - A02BG50AA/AC (4970027002B02) 2002 ATV MAGNUM 500 2X4 HDS DRIVE SHAFT - A02CB50FC (4974857485B03) 2002 ATV SPORTSMAN 400 DRIVE SHAFT - A02CH42AA (4968536853B05) 2002 ATV SPORTSMAN 400 DRIVE SHAFT - A02CH42AA (4968536853B05) 2002 ATV SPORTSMAN 400 DRIVE SHAFT - A02CH42AA (4968536853B05) 2002 ATV SPORTSMAN 500 ALL OPTIONS DRIVE SHAFT - A02CH50 ALL OPTIONS (4967436743B02) 2002 ATV XPEDITION 425 DRIVE SHAFT - A02CK42AA/AB (4970327032B01) 2002 ATV SPORTSMAN 6X6 DRIVE SHAFT - A02CL50AA/DA (4967986798A14) 2002 ATV INT'L BIG BOSS 6X6 DRIVE SHAFT - A02CL50AA/DA (4967986798A14) 2002 PPS LUH 6X6 PPS DRIVE SHAFT - C02CL50AB (4972367236B01) 2001 ATV XPLORER CV JOINT - NEAPCO - A01AG25CA (4963866386B001) 2001 ATV SCRAMBLER 500 4X4 CV JOINT - NEAPCO - A01BG50AA (4963766376B003) 2001 ATV SCRAMBLER 500 4X4 CV JOINT - NEAPCO - A01BG50AA (4963766376B003) 2001 ATV XPLORER 400 CV JOINT - NEAPCO - A01CG38CA (4963916391B003) 2001 ATV DIESEL DRIVE SHAFT (If Built After 5/01/01) - A10CH46CA (4964376437E04) 2000 ATV XPLORER CV JOINT - NEAPCO - A00AG25CA (4954865486B003) 2000 ATV SCRAMBLER 400 CV JOINT - NEAPCO - A00BG38CA (4954845484B005) 2000 ATV SCRAMBLER 500 CV JOINT - NEAPCO - A00BG50AA (4954855485B005) 2000 ATV XPLORER 400 CV JOINT - NEAPCO - A00CG38CA (4954875487B006) 1999 ATV SCRAMBLER 400 CV JOINT - NEAPCO - A99BG38CB (4952505250b004) 1999 ATV SCRAMBLER 500 CV JOINT - NEAPCO - A99BG50AA (4949714971b004) 1999 ATV XPLORER 400 CV JOINT - NEAPCO - A99CG38CA (4949634963B005) 1997 ATV Swedish Sportsman 50 CV JOINT - NEAPCO SPORTSMAN 500 W97CH50A (4939993999B003) 1997 ATV SPORTSMAN 500 CV JOINT - NEAPCO SPORTSMAN 500 W97CH50A (4939993999B003) http://www.ebay.com/itm/Sixity-Polaris-1380063-1380066-1380114-2200960-OEM-Axles-Replacement-Front-lu-/161173526850?pt=Motors_ATV_Parts_Accessories&hash=item2586b0d942&vxp=mtr |
Thanks OPT!
Last question is I got newer model Polaris rims and when I mounted them on the bike, the wheel studs are too short whereas the lug nuts can only grip about 1 or 2 turns on them. On the old steel rims when the lug nuts are tight the lugs come completely through the nuts. Do I need spacers? Change out the studs? What's the fix to this? OLD RIM & STUD LENGTH: https://atvconnection.com/forums/pic...ictureid=45861 https://atvconnection.com/forums/pic...ictureid=45860 NEW RIM & STUD LENGTH: https://atvconnection.com/forums/pic...ictureid=45859 https://atvconnection.com/forums/pic...ictureid=45858 |
No need to get expensive wheel spacers. Just get longer hub studs.Plenty places around that have them.http://www.ebay.com/itm/POLARIS-SPORTSMAN-EXTENDED-FRONT-REAR-WHEEL-STUDS-Grade-8-Fits-450-800-ATVs-/291388819220?pt=Motors_ATV_Parts_Accessories&hash=item43d8208714&vxp=mtr Plus didn't notice about needing a fan also. You can get a 9" Spal fan here,same as the one you have.http://www.ebay.com/itm/Spal-Polaris-Cage-Fan-2410123-Sportsman-6-X-6-2002-/131419313090?pt=Motors_ATV_Parts_Accessories&hash=item1e993393c2&vxp=mtr Plus several other places like this one that's cheaper than oem parts.http://www.the-fan-man.com/shop/-c-33.html
Thank you sir! I have the parts lists and will be shopping and waiting for deliveries. Then it's time in the shop to do installs. You know I'll post the progress and events when complete unless I trip and fall and need more guidance. :D
:thanks: :thanks: :thanks: :thanks: |
Wheel studs are about a buck a piece from a dealer.
Winchester120, Thanks man. I think my closest dealer is about 50 miles from me but I was surfing the web at work last night and have my shopping complete. (1 Axle, fan, set of extended lugs & black lug nuts). Unfortunately, nothing should be delivered until Tuesday or Wednesday of next week. Boy, it's gonna be a REALLY LOOOOOONG weekend :mad:
partial update:
While waiting on parts, I decided to switch the tires to the new rims. The following pictures show my rim test fit on the bike and the new tires mounted. Still waiting on the extended lugs but then I'll be good.
https://atvconnection.com/forums/pic...ictureid=45873 https://atvconnection.com/forums/pic...ictureid=45872 https://atvconnection.com/forums/pic...ictureid=45871 https://atvconnection.com/forums/pic...ictureid=45874 |
I have an axle to fit your old quad on my parts machine I would sell pretty cheap if youre interested.
Originally Posted by HeavyChevyWes
(Post 3280075)
