02 sportsman loosing charge
HI.New to forum .my 02 sportsman 500 is draining my battery when riding but battery is new and holds charge when sitting. Starts up fine if I pull start it.any ideas? thanks for any information.
First off pop the front panel off and see if any wires have pulled loose from the regulator. Common thing on many Sportsmans. If all are hooked up check what the voltage is at the battery slightly above an idle. If it just shows battery voltage or less usually the regulator is faulty.Plus it's been updated which usually means something. Item #35 on the parts break down. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Supposedly this one will work if you need one.http://www.ebay.com/itm/Rectifier-Regulator-FITS-POLARIS-ATV-4060173-2203636-NEW-/270668566659?hash=item3f051a9083&vxp=mtr
(Post 3296494)
First off pop the front panel off and see if any wires have pulled loose from the regulator. Common thing on many Sportsmans. If all are hooked up check what the voltage is at the battery slightly above an idle. If it just shows battery voltage or less usually the regulator is faulty.Plus it's been updated which usually means something. Item #35 on the parts break down. Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Supposedly this one will work if you need one.Rectifier Regulator Fits Polaris ATV 4060173 2203636 New | eBay
Welcome to the forum Ron.
