2003 Sportsman HO 500 - rear break bleeder screw stuck
An easy out or a set of screw extractors. Best to use a little heat and even some PB Blaster on rusted screws and bolts. Drill a pilot hole and use the easy out.Just have to take your time.
Misread your post,thought you'd broken the bleeder off. Heat and a little penetrant can still help also with frozen/rusted bleeder valves.Don't break it or you will need the easy out..
Any auto store should have them. Don't hold me to it,but believe 1/4-28 is the size. If in doubt take one that's easy to get out and match it up.
danger2nature
2) Chassis problems..
Mar 22, 2016 09:43 AM
