reverse override mod for 2002 and 2008 sportsman.
What ever wire color is shown for reverse on your model then. If it shows white,then white it is,but on most models still have a purple wire for reverse.Strange...
This is the only thing I can find on the newer style.
Reverse mod- pull the headlight pod off and disconnect the two harnesses going to it. On the big harness locate the gray/orange wire and use a splice connector with another 8" piece of wire and have a female spade end connected to it. Now do the same with the brown(ground) wire coming off the lighter/accessory plug. Hook the two female spades to a toggle switch that you can mount on the pod and you are done. You will have to turn the switch to the "off" position to use the yellow override button to scroll through the different modes or if a young or inexperienced rider is on it for safety.
#15
#18
I have a 2005 Sportsman 500 HO. If I do the switch and leave it on all the time, is it going to hurt anything? I hardly ever use it as Mode to cycle through the options in the speedo. So I wanted to check and make sure if I do this switch bypass, that leaving it on all the time isn’t going to hurt anything.
#19
Leavitt Woodland
1) Engine problems..
03-24-2016 02:55 AM
