'06 Sportsman - adding a fuse block
Has anyone added a fuse block to an '06 or similar sportsman? I have basic electronics knowledge but never done this on an ATV. If anyone has any suggestions, pictures, it would be appreciated....thanks..
All the solid state circuit breakers are in the controller modules on the 2006 carb and efi models.
I see. So it sounds like I need to add my own accessory block. I'd like to add a relay that only turns on the breaker when the key is on. Is there a wire somewhere I can tap into?
Man I wouldn't do it. There's so may functions that either one of these modules control and they have enough problems on their on. I wouldn't add to it.
So there is no way to add accessories like a light bar or USB charger?
Yes their is at least one red white wire in the harness under the front panel that's dedicated for accessories. I that's not strong enough then look at you tube on what some owners have done.
