2001 spoetsman 500 HO radiator relocation
This is from another forum, kinda old thread but see if you can get some ideas:
01 Sportsman 500 Radiator Relocation - MudInMyBlood Forums
These are the hardest to bleed Polaris models other than the Rangers with their long hose runs. Main reason is the the engine coolant return line goes back to the remote coolant filler neck instead of directly back to the radiator. Plus you have to make sure the radiator is clean front and back. Helps to jack up the machine,squeeze the hoses to help remove trapped air pockets and let the fan cycle on and off several times. This problem wasn't solved until the later 2004 or 2005 models when the return line ran straight back to the radiator. I know what a pain it is to bleed these models and the time it takes sometimes to do it right.
