2001 polaris xplorer 400 need help - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 05-02-2017, 10:18 AM
Default 2001 polaris xplorer 400 need help
hello there ive recently purchased a 2001 polairs xplorer 400 4x4, this is my first ever quad.
i was performing a little maitenance on the machine when i removed the plastics from by the foot brake area and noticed the casing in there has a crack in it. i believe it may be the tranmission gear case? but im not sure just looking for some clarification on this. it is the area that has the fill plug as well
Old 05-02-2017, 10:47 AM
This is the gear case. Hairline cracks can be fixed with epoxy,but if it's a large area a new case half may be needed if the case can't be welded.
Old 05-27-2017, 05:17 PM
Default Old Polaris tech
Quote:
Old Polaris tech I have a question I have a 98 Polaris xplorer 400 the engine is locked up but the clutch will turn both ways a little bit maybe a 16th of a turn. I have heard that the piston in these machines aren't that great and part of it may have broke off and fell down into the crank case and that's what's preventing it from turning over? Have you ever experienced that or is someone blowing smoke up my aSpam wordSpam word Spam wordSpam word Spam wordSpam word Spam wordSpam word ? Any help would be appreciated as this is my first bike and excited to get it running.
Old 05-27-2017, 05:37 PM
Common problem if these cast pistons were worn past .005 clearance. Skirts would break and lodge down in the bottom. If you can't turn the engine over then sounds like you need to tear the top end down. You also really need to check for ANY up and down play on the rod at the crank shaft. If any play is found,a rod kit and bearings will be needed along with a new top end.I've seen people take short cuts when this happens and just do a top end only then have lower rod bearings take out a new top end.If you're lucky and there is no up and down play,the bottom end needs to be flushed out to get the small pieces of piston out. Wiseco is the best pistons out there when you have it bored to the next over size that will clean the cylinder up. Plus replace the crank seals that people always forget about. Before you do anything,take off the recoil cover and see if the bendix might be jammed against the flywheel. Might be something as simple as that unless it locked up on you while riding. It really helps to have a service manual if you don't have one. https://www.tradebit.com/filedetail....service-repair
Old 05-27-2017, 08:16 PM
I just pulled the cylinder off and half the piston was broke off down in the oil and crank what's your recommendation on flushing that out of there and I'm assuming the motor needs to come out to be replace the piston. Also there was no play in anything
Old 05-27-2017, 09:18 PM
That much metal particles will be hard to get rid of out of the bearings and nooks and crannies,but you could fill the crank case with kerosene or naphtha run the rod around several time to help work out particles,drain and do the same thing again.Use some cheap oil and fill the crank case up and work this around then dump it out.Yes the engine needs to be removed to do this right or have some guys that can help lean the machine over.There is also a 10mm drain plug at the bottom of the engine that can help.If you're able to get all the crap out you may be able to get by with just a top end.Examine the rod carefully to make sure it isn't damaged or bent or all the flushing would be for nothing. I wouldn't do just a top end on and old machine like this,but that's just me.. IF you're going to do a top end only you can do a top end with out having to pull the engine. It's just easier to work on if you do. May the force be with you as they say.
Old 05-29-2017, 01:36 PM
Not 100% sure but is that hole supposed to be there in the crank case down by the crank?
Old 05-29-2017, 01:37 PM
There is a hole in the case down by the crank on the front side is it suppose to be there?
Old 05-29-2017, 01:38 PM
Old 05-29-2017, 02:41 PM
I don't see where it's coming out on the other side so idk what it it leaking into
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
