Polaris 250 flooding
1997 Polaris trail boss 250. Top end recently rebuilt. Did a carb kit at the same time. Floods like heck now, was fine before rebuild. I can get it started and running smooth and strong with the fuel petcock off however as soon as I turn the fuel on it floods immediately. I can keep it running by turning the fuel on for a second to fill the bowl as long as I turn it back off quickly. Just put a second carb kit in and same symptoms. I'm stumped. I feel like I'm either missing something simple or the carb itself is no good for some reason. Maybe I lost or damaged a small part during the initial rebuild process and it's something that's not in a new kit? I checked the floats and they seem fine. I've done carbs on these motors a number of times with good success. Should I just buy a whole new carb?
Sounds like you're missing something too. Either the float arm is adjusted wrong,float arm and pin possibly worn out. They don't come in the kits and are often over looked when rebuilding this carb.If the float arm is wobbly,probably time for a new one. Here's a couple videos that may help.
I know. That's why I'm tempted to grab a used carb off eBay rather than guess at part after part. Should be able to use all the parts that came with my rebuild kit to get a used one up and going.
Actually a very simple carb to rebuild.Just retrace your steps. See if the pdf fuel section from the manual helps any.https://www.google.com/url?sa=t&rct=...U2gGlaHJWSIlbA
Persistence pays off. Thanks to OPT for giving me the encouragement to fight through the frustration. I reviewed the document as you suggested. Then decided to check the vent line routing because everything INSIDE the carb seemed ok. Turns out I had all 3 lines coming from the carb connected to the 3 ends of the tee. Quick fix and the motor is purring like a kitten again without a hint of flooding. They way I had them must have been pressuring the fuel because it was flooding so quick I don't think it would flood that quick with NO needle valve installed.
I own two of these 250's and have been to hell and back with them. Lots of angry moments turning wrenches but they sure are fun when they are up and running.
Glad you solved it..These tees and check valves caused more problems than what they were worth. When one came in for a carb job I threw them away,ran separate vent lines and zip tied them to the throttle or choke cable,terminated the ends under the back of the tank.The float bowl drain/over flow tube I made go past the bash plate to keep gas off the engine.
