2018 570 sportsmen Utilty Edtion
From ATV.com write up article: low-speed limiter which allows the rider to set the maximum speed between 7-14 mph (11.3-22.5 kph) in 1-mph (1.6-kph) increments, making it ideal for spraying and low-speed tasks; work-specific gearing with lower gear ratio provides more low-end torque.
As for use...owners manual will give instructions on that. Probably a setting on the instrament cluster menu.
