05 Sportsman 700.. NO POWER
Just bought a 05 Sportsman 700 (CARBED) the other day and rode it all day no problems loaded it on the trailer got home went to start it to unload off the trailer and it had no power at all with key on or off. I bumped the head light on the handlebars with my hand and I had power again. I started it and it ran for like 5 seconds then shut off with no power again and haven't had power since then. I'm getting 12v to the yellow wires on the ignition switch & the kill switch wires all have .50v or less to them. Is there anything I can test with a voltage meter? ECM bad?
Look for any obvious shorts,bare wires.Head light pod is one of the areas that have had quite a few. Look around the harness that runs through it and the main harness below it. The headlight connector and wiring is another place that shorts have happened often because of the dips and bends. If you get that sorted out and still have problems,then yes the the other obvious cause is the ecm module. If it still happens to have the black Chinese ecm you can still have that replaced under the recall.If it's the newer silver one,this one you have to pay for. I'd check around on the price.
Already looked for broken wires and everything looks good. Someone said I should have 12v to the two red wires (one solid red & one red/white stripe) that run into the plug for the ECM and I don't have power to either. There also is two red wires (both solid red) that run from the ECM plug to the solenoid but isn't wire to the solenoid they're just cut? Neither have power to them. Nothing on the quad has power besides yellow wires that run into the ignition switch plug & the main positive wire.
You've got two fusible links that aren't even hooked up and that's part of the power problem.Go through the wiring diagram in the manual. It'll help you on sorting out this mess.2005 Polaris Sportsman 700 Service Manual PDF Download
Well I've ridden the Sportsman for about 12 hours since the last time with the no power issue and now have a new problem.. it rained pretty hard yesterday and I went to ride the sportsman and the digital dash is all screwed up. Says AWD is on when it's not, AWD doesn't even work now, display sometimes turns off then back on, half of my fuel gauge is faded away, when I put it in Park it says I'm in Reverse, tachometer works then I rev it and it drops to zero. There is no water inside the speedometer that I can see but I brought it inside to dry anyways just to make sure no water was inside and it still didn't help. Any ideas?
Rpm signal starts from the stator,to the ecm and from the ecm to the speedo. Same for the power to the dash,the ecm controls that also. It may be a connector or internal speedo problem but I still wouldn't rule out an ecm starting to go out. So many functions that this one little box controls and different sections of it can go out independent of the rest.The manual is your best best to do the pin check on the speedo harness connector. They can cause problems also and this can help narrow down the problem area.
