1995 magnum 425 regulator
Sounds like you're getting the reverse limiter in there especially with that solid black wire. Get the pdf manual for 5 bucks and it has the wiring schematics and anything else you need. Both the 2x4 and 4x4 share the same regulator.1995 Polaris Magnum 4X4 Service Manual PDF Download
Ok,then hook the red to red, solid yellow to stator yellow,yellow/red to stator yellow/red,yellow/black to stator yellow/brown wire.Brown wire is a ground and shows a connection for it also.
A lot of aftermarket regulators don't match colors correctly. Main ones to match are the red,yellow,yellow/red. What one is left over just hook it to the last stator wire. In your case stator yellow/brown to regulator yellow/black. If it has a bullet connector on the brown regulator wire,looks like you can pull the brown ring connector wire that's grounded to the old regulator and chunk it.Then insert the brown regulator wire in its place on the harness ground connector.
