Found my oil leak - cylinder gasket
#101
Replace the cracked boot and then check compression. Should be between 55-90 psi(or a little higher) because of the decompression device. Plus looking back,what did the machine shop do to the stator plate you mentioned? Plus is the timing mark on the plate aligned with the case mark?
Compression test failed, got zero compression. Will recheck the timing next.
The carb boot isn't cracked, just not sealed to the head.
#103
Normal for pressure from crank case vent into the air box as this recycles gasses back through the air filter and carb into the combustion chamber again. If it failed the compression test(less than 50 psi) and if the cam timing and valve clearance is good,then I'd do a leak down test. If bad enough you'll hear air pressure through the exhaust( usually valve problems) or through the carb or air box,normally piston/ring problem.Plus spray soapy water around the base and head gasket area while it's under pressure.
#104
I had taken the head to an automotive shop to have them check and reseat the valves. Gave them the specs from the manual. Also gave them new valve seals. They said it was all good when they were done.
I will get the leak down test done next. There is zero compression - so hopefully we can find the leak.
#105
I checked the timing, and it's still good. I adjusted the valve clearances after putting the chain back on, so that should be ok. There is a new exhaust rocker arm. The cam lobes looked good.
Sounds like a valve not closing to me.
#107
https://www.manualslib.com/manual/81...page=56#manual
#108
Just pop the valve cover at tdc as you have pictured. You can tell real quick if any valve spring may be lower indicating a stuck/bent valve.Plus you need to use two feeler gauges as the manual says to set clearance on the exhaust rocker arms. This keeps the rocker arm from cocking and possibly spiting out valve keepers. Old English bike riders sometimes found that out the hard way years ago.
#110
As long as you had a .006 feeler gauge under each rocker arm that's what I meant.Get both sides close while you do a final adjust on one side and tighten the nut. Then go to the other rocker arm adjuster and set it. This is just a precaution to keep from popping keepers if the forked rocker arm ever happened to get in a bind.Doesn't happen much on newer engines,but was a big problem years ago if not done right.
