Polaris trail boss 250 - no lights
+1.... Have to have a good battery for the voltage from the regulator to go to.If the battery is bad or even missing,can't take the voltage, it will take the path of least resistance and blow out dash bulbs and head light bulbs.
I ended up throwing a new battery in and none of the electrical things worked. No lights, electric start, neautral light. Even if the bulbs blew, shouldn't my electric start work? Is there a fuse that could have gone? Fwiw, I did have the battery in whenever I rode it.
There's a main 20 amp circuit breaker in a plastic pouch located up from the battery on the frame. If there isn't voltage on each side of the red wire leading in and out,slice the pouch open and check the circuit breaker. If it needs to be replaced,you can get these at any auto store for a few bucks.This is probably your main reason for no power to the dash lights,starter,head lights,etc.They can get moisture and corrode or just wear out over time.
Still having troubles
Ok so I charged up the old battery and only took a couple minutes until it was fully charged, so guessing battery wasn't an issue. Just split open the black pouch and the unit looked clean with no corrosion. So have a couple questions. When I check the voltage, do I need to have the ATV running or doesn't that not matter? I turned the key on and tested it but honestly I have no idea how to use this volt meter lol. It's a super complicated commercial Fluke brand. I have a little tester that I use for outlets, I slide the flat end into an outlet and it beeps if there is voltage. Could I use that?
Turn the meter on to dc volts. Black lead to battery negative post or good ground. Positive lead to first side of the breaker leading from the battery. Should have voltage.Same thing on opposite post.If no voltage on the other breaker post,the the breaker has faulted and needs to be replaced. IF you have voltage passing through the circuit breaker, problem could be in the left control off/on switch.Work the switch back and forth and see if you have power.Sometimes corrosion on the switch can cut power.If you have an older model,should be a terminal board on the left side of the frame under the front cab.Should have power on the red wires,the red/white wire terminals should power up with ignition key switch on.If they don't, the problem could be the left control switch is faulty and needs to be replaced. A simple test light can work also. Just hook it to a good ground or battery neg post and probe connections.
