07 Polaris 500 sportsman idles good dies with throttle - ATVConnection.com ATV Enthusiast Community
Thread Tools Search this Thread
Old 01-15-2018, 11:41 AM
Default 07 Polaris 500 sportsman idles good dies with throttle
Need help with my 2007 sportsman 500 I just did timing chain guides tentioner valves the whole 9 cranks and idles fine but if I touch the throttle it dies I have checked timing fuel pressure (35ish) and I'm stumped any help would be appreciated
Old 01-15-2018, 02:16 PM
Check your spark u could be getting a weak spark thats why it idles but dies when u give it gas
Old 01-15-2018, 02:35 PM
35 psi is a tad on the low side as the manual shows 39 psi +/- 2 psi.May or may not be enough to matter. Check the grommet (Item #9)under the t-bap for any splits. If damaged it can cause problems by sucking in air. Plus check the connectors and the wiring from the t-bap and tps sensor for any bare spots or soft feeling wires from internal melting.Several things could be causing this problem and best to have the manual and go through the trouble shooting checks to help narrow it down.Plus if it's not throwing codes this makes it a little bit harder to track down.2007 Polaris Sportsman 500 EFI Service Manual PDF Download Even a short in the etc switch could cause one to die. Just go through the electrical checks and efi checks and tests. Sensors were usually not a problem area but wiring and connectors were.
07 Polaris 500 sportsman idles good dies with throttle-736050e422ab98c5dbca7282f9dbf63091484cf8.png
Old 01-15-2018, 08:19 PM
Ok so I got a little thottle today not much it came off of idle for about 10 seconds I got it up to maybe 2200 Rpms but any more thottle it pops and starts to desend back to idle or dies
Old 01-16-2018, 05:57 AM
The manual can still help you narrow things down. Go through the electrical and efi check list and it can save you time and frustration.Just too may things on efi machines that could be causing the problem.Plus the most common problems we had were the tbap wiring harness and connectors. That along with an occasional tps harness. Not the sensors themselves. Look above in the Polaris expert section "sticky" on 700/800 efi problems. This applies to most all efi machines including your 500.A member started offering better harness repair kits than what I had from Polaris that kept failing.This can be one of the reasons or the main reason for the back firing and dying.This was another common symptom of a t-bap wiring harness short.https://otbpowersports.com/products/
Thread Thread Starter Forum Replies Last Post
2002 sportsman 500 4x4 idles good but bogs and backfires when throttle pressed BAMBAM11336 Polaris 18 07-20-2013 01:52 AM
HELP: Starts & idles... dies with throttle. BJ426 Polaris 4 11-15-2012 08:57 PM
Need Help!! Blater idles But when i push the throttle it dies!! mxXXrider88 Yamaha 3 10-20-2011 07:38 PM
Dies, Idles Fast, Runs Fine, Dies, (repeat) loranimal Polaris ATVs - Ask an Expert! 7 09-19-2011 08:12 PM
LTZ400 Idles great but dies when I throttle. DuHaas Suzuki 0 12-05-2010 04:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
