Polaris sportsman efi 500 wont start in gear
Hi just brought a 2008 efi 500 and it wont start in gear and you have to put it in park or neutral every time you go to start it up, I thought if you applied the brake it would start but it doesn't. I have owned 2 500 1998 and 2000 sportsman and never had that issue, is there anything I can check or change as this is really frustrating thanks
My best guess is it just doesn't know you have the hand brake on. Some of the wires on the left handlebar would have to send a signal wherever it goes. You could do a continuity test, and if there's an open circuit trace the wires to see where the problem is. It could just be a bad connection where the wires are plugged in.
I think most models wouldn't start in gear. Neither my Brute Force 650 nor my current King Quad would start in gear. I still have to pull the hand brake to get the King Quad to start in neutral. No park position available, it has the old school L-H-N-R configuration with a manual parking brake substituting for park in the transmission. I wish the machines with park would still have a manual parking brake also. Its nice to lock it in if you stop for a moment on uneven ground so your machine doesn't roll away.
Most of the newer ones have the pressure switch on the brake line connector block that controls the brake lights and also completes the circuit for the starter to operate. Don't remember off hand on the 2008 models.Too may changes over the years to keep up with.
