Date of manufacture question
I have a 2003 Sportsman 700. VIN says 2003. The only date I see on this thing is on the engine, which is 6/15/02. When shopping for parts, I often see "if build after ....." or "if built before ....". Is the engine date considered the build date for the vehicle? Obviously engine parts are a given, but would this engine date also determine build date for brakes and chassis parts?
Call an area dealer with your vin#. Data base has the build date,original buyer(if not you) date of purchase along with all bulletins performed or needed to addressed. Major difference on the before and after was the rear caliper and the ignition system that changed over to a Kokusan from the troublesome Ducati. There may be some other small part differences also.
