Weap hole
My water pump weap hole is leaking so I know the seals shot.( Funny even I replaced it last month). I have a big ride I've planned for since january. is it alright to go on the trip and or How long until something like this becomes urget?
roll the dice as you really can never tell. if you have time I would fix it before you go. just my .02
If its just a drip you MIGHT get away with it if you keep a close eye on it and refill often. But you risk causing more serious damage if you run it hot because the coolant gets low. I'd try to get it fixed if possible.
New seals don't normally leak if they aren't damaged. I don't know what you used but the wrong tools could mess it up.
