2007 Sportsman 500 Charging issues
Hello. I am working on a sportsman 500 for a friend and he said the battery is dead always. So I tested the voltages. It is 11.8 with the quad off. When I start the engine it is only 11.9. I figured the stater is shot. I have tested the 3 yellow wires together and got .4 ohms but when I test the brown wire on the plug to the yellow wires I get .1 ohm. I am assuming the brown is a ground and it should not have any ohms? It should be a open circuit? Any help would be Appreciated
I'm leaning towards a bad stator also. Pull the drain plug under the pull start. The handle is a weak point for water to get in. Water+electricity, no good.
Take a look at youtube on how to test a stator, there are lots of videos on it.
Replacement isn't that bad of a job. You will need a flywheel puller.
Ok so I finally had time to do some tests please let me know if I did them wrong. So I tested y1 to y2 y3 and got a open circuit. Tested y2 y3 and got .4 ohms. I then tested all of them to the a ground. Used the transmission mounting bolt that was close? Not sure what they mean if they want the battery ground or just a ground on the quad. They were all a closed circuit to ground besides Y1 I am guessing a bad stator? The quad does get up to 12.0 volts when reving it ?
cody500ho
14
08-14-2015 05:03 PM
