Starter switch wiring question
I have a 2002 scrambler 500 that had corrosion in the starter on/ off headlight switch , I purchased a new switch from amazon but it does not have the up start on it ? I plugged it in and all works but when I turn on my key ,atv starts and continues cranking while running , how can I make this work ? Can I interrupt a wire with a spring loaded switch coming off this new switch ? I spent $89 for the switch didn’t see the fine print in the description (no up start) dealer wants 249 , if I can simply install a “off the shelf” push button switch by cutting one wire I would like to do that , can anyone help me out that may know about this ?
kfxridr
02-27-2009 10:32 AM
